Linux wine config problem
When i try to start bricscad under linux i m getting these errors......I guess its an open gl problem ...does anyone have the same problem? or the solution??Invoking /usr/lib/wine/wine.bin icad.exe ...fixme:opengl:query_function_pbuffer gl_version is: "1.5.3 NVIDIA 71.74"fixme:opengl:query_function_pbuffer glx_exts is: "GLX_EXT_visual_info GLX_EXT_vi sual_rating GLX_SGIX_fbconfig GLX_SGIX_pbuffer GLX_SGI_video_sync GLX_SGI_swap_c ontrol GLX_ARB_get_proc_address "fixme:opengl:query_function_pbuffer gl_version is: "1.5.3 NVIDIA 71.74"fixme:opengl:query_function_pbuffer glx_exts is: "GLX_EXT_visual_info GLX_EXT_vi sual_rating GLX_SGIX_fbconfig GLX_SGIX_pbuffer GLX_SGI_video_sync GLX_SGI_swap_c ontrol GLX_ARB_get_proc_address "fixme:ole:CoRegisterMessageFilter stubfixme:ole:ITypeInfo_fnRelease destroy child objects.................fixme:ole:RegisterTypeLib Registering non-oleautomation interface!fixme:ole:RegisterTypeLib Registering non-oleautomation interface!tion interface!..................fixme:wintab32:WTOverlap (0xc04, 0): stubfixme:wintab32:WTOverlap (0xc08, 0): stuberr:x11drv:X11DRV_CreateWindow invalid window width 1808180742err:x11drv:X11DRV_CreateWindow invalid window height -190056504err:x11drv:X11DRV_CreateWindow invalid window width 1808180742......................
For enlisch folks, my answer wil be in dutch because dirk is from belgium and i'm from holland.Dirk,Ik denk dat je een probleem hebt met jou driver of Xorg instellingen. Wat voor video kaart heb je en welke driver gebruik je in Xorg. En laad jij de GLX module wel?Groeten Emiel
But we might run into similar problem...:(And I'm not even "english" folks !
