BricsPro6 and X-Ref
Hi -Generally, BricsCad 6 is a great improvement - thank you Brics.Now, about X-refs:1) Brics can't remember the path for X-Ref files from one session to the next.2) The new "Refedit" commands are intriguing. I can edit a file that is x-reffed in a drawing from within the drawing; but, the x-reffed drawing is not changed until I end the cad session and restart. Then - other drawings that use that same reference do not update - and I can't force them to do so. What's up?Vaughn McIlrath
  • Sorry - No. 2 above was due to my cofusing use of a duplicate subdirectory. REFEDIT WORKS!About No. 1: By putting the path I wanted into the "Additional Xref Search Paths" window in the Xref Manager window, the path sticks.Thanks again, Brics.VM
