disapearing en reapearing of objects
When I zoom in, some items of my drawing disapear from my screen, when i zoom out the reapear again.This makes drawing difficult because I do a lot of zooming.Is this a setting in bricscad or a bug?
  • The root of this problem is in the code that speeds up the zooming and panning operations by filtering out entities that are not actually displayed on screen. We are currently working on a fix that specifically concerns a problem of disappearing entities after installing a rotated UCS. Is this also what you are experiencing? If so, for the time being a regen will make the problem go away. If not, could you please enter a support request and attach a drawing and a description of what we should do to trigger the problem. We highly appreciate your cooperation, we want to fix this annoying issue with priority.Best regards,Hans
  • When I'm in UCS-world I see all. It is indeed when I am in an rotated UCS when I have the problem.Thanks for your help.
