Alternating Views with 3-d Drawings
I am having difficulty with Bricscad 6 ability to switch between "top view" and several other modalities: "aerial right front", "aerial left front","front" and "aerial right and left rear" views. The Program 'hangs' until I switch to Layout view and then come back to Model view. Sometimes I also have to command through to 'Zoom Extents' or 'Zoom-In' to return to Top View after the program brings up a blank screen. I have a 2.8 gig Hard drive with 512 SDRAM and 32M Video RAM/ Windows XP.
Most likely you experience the same problem as explained in the thread 'Disappearing and Reappearing of objects'. We are preparing an update release that will fix this problem. The actions you describe to remedy the problem look like they all trigger the REGEN command, so I think that as a temporary workaround keying in regen would bring back the disappeared elements.
