Extended entity data
Is possible use extended entity data in Lisp of IntelliCAD? I tried following list by function (entmod), but without succes.((-3 ("O$L-S" (1000 . "fo"))) (-1 . ) (0 . "LINE") (5 . "38") (67 . 0) (8 . "0_OBRYS") (62 . 256) (6 . "ByLayer") (48 . 1.00000) (60 . 0) (39 . 0.000000) (10 -11.5401 -24.6855 0.000000) (11 -2.13370 -28.9076 0.000000) (210 0.000000 0.000000 1.00000)) Thank you for responseLukas
I have not studied the use of eedata myself, but I have a routine which works in Intellicad and uses extended entity data.
