BOUNDINGBOX
The "boundingbox" lisp command fails on blocks that contain Mtext or truetype fonts. From vb it does work. How do you access Icad "events" from VB (not VBA)?
Events can only be used in VBA applications, these run in the same process as BricsCad V6. VB applications typically run as a separate process and the callback events will arrive out of synch. This is a problem that requires a fundamental re-achitecture to solve and hence is not likely to be solved soon.
