Scaling on printer
I draw a rectangle on a Layout tab of 270 * 150 mm.I send it to a HP LaserJet2100 printer with settings:-plot extents-user defined scale 1 mm = 1 drawing unitI measure on the printer paper a rectangle of 273 * 150.5 mm.Also on a DesignJet 1055 similar changes in scaling.Anybody seen this before or knows how to plot 1:1 to a printer?
  • This problem has been reported last week. We have been working on a fix and are currently testing it. The problem was introduced between build 5.1.0014 and 5.2.0010.
  • Noted. Thanks for replying.
  • The fix for this problem with print scale is included in versions 6.1.0003 and higher
