Using scriptfile for printing
I use the following scriptfile to print a drawing (A4 Portrait):PLOTYmodel\Hs004\Printer 05 tray 9A4 (210 x 297 mm)MillimetersPortraitNExtents1:10,0YWila.ctbYNNNYWhy is the result each time different? When i print by using the print dialogbox, everything works fine. It looks like intellicad keeps using "old" parameters when printing a drawing by using a script file.When is this problem going to be solved....
