Print setup for BricsCad 6.1.0005 and AutoCad 2002
I'm having problems setting up drawings so they will print correctly in both BricsCad and AutoCad. If I create a new drawing in BricsCad and set up a layout in landscape mode, then if I try to open the drawing in AutoCad, in paperspace it is in portrait mode. If I then do a print preview the preview is in landscape. If I correct it in AutoCad then BricsCad displays it in portrait mode.I have similar problems if I create the drawing with AutoCad, as soon as I save the drawing with BricsCad then AutoCad cannot display the orientation correctly.Is this a bug or have I missed something in the BricsCad print setup?
  • Ray,I have experienced this same problem. I even tried doing a "Pagesetup" in Acad but it didn't fix the problem.
  • FYI: We could confirm this problem and currently are working on a fixBest regards,Hans
