Files of Type
How do I change the "default" Files of Type from .dwt to .dwg. . .(this seems so easy and I swear I can not figure out how to change this. . .and I know it's a stupid question. . .so I apologize in advance!)
  • Mike I guess you just use a .dwg drawing as your template instead of dwt.May I ask someone what the use is for the new .dwt format ?The only use I can see would be if the would open as un-named file that asks for a new name as soon as you hit save. (As in most other applications).Else I´m missing somethinge here like MIike.Also I would be happy if the path to blocks would automaticly put you in the block directory from the open block dialog.The path has been there for years now without doing anything.
  • That is what is so strange Patrik. . .If I open BricsCAD (opens with a blank drawing) and then go to FILE->OPEN. .the "files of type" box ALWAYS defaults to file type of .dwt. . .And my default ICAD drawing IS a .dwg file.I too am still trying to figure out the .dwt and I'm with you on the block directory. . .thank heavens for DocCommander or I'd CONSTANTLY be hunting for it!Thanks!Mike!
