sds_grread
Setting the cursor type does not work.There seems to be a mismatch between the arguments described in the help file and the arguments available in the function. The bits argument doesn'rt support the number 4 and the cursor argument is not available.Anyone having a solution for this?
setting the cursor does work in the lisp version grread, but the sds function does not allow to pass this parameter. The documentation is causing confusion here. The documentation of the sds function was clearly created by adapting the documentation of the lisp function. kind regards,Alexander Van Heuverzwyn,Bricscad
