Wish List - Explorer - Layers
We need to be able to change the Linetype and Plotstyle of multiple layers at once. The properties dialog does not include these properties.
  • Explorer can change the Linetypes of layers. Lineweight can apparently be changed that way too, but I have never applied Lineweights. Is that what you mean by Plotstyle? I just plot thickness by colour as was the only way in the past.
  • When using STB/Named Styles, the lineweight and plotstyles are controlled by the user in the same manner as linetype. It appears as explorer only allows the user to change them one at a time. It would be much more useful if we could select sereral layers and change them at once.
  • Still a little unsure what you are trying to achieve, but yes it would be useful to manipulate multiple layers in a single operation. I use script files to make, freeze, thaw and change properties of groups of layers for clients who use different colour schemes for plotting. I use names which lend themselves to batch reference so scripts can refer to them as say D* for DW2, DW3, DW5 etc.The new Layer State tools don't quite achieve their aim for me, but not sure how it could be done better.
  • the properties dialog for layers indeed is missing some features: lineweight, plotstyle, plot/no plot. We will add them shortly.In the latest release there is also a bug in the properties dialog: all the layers get the same color after using it. We will fix this as soon as possible and provide an update.Alexander Van Heuverzwyn,Bricscad.
