Opening dialog contra new drawing
Is it possible to adjust BricsCad to show a dialog like AutoCad where you can select either a new drawing or start with browse/opening an existing drawing.I believe that I saw that once som months ago in an earlier version, but can not find it now.
You can use the command NEWWIZ to make a new drawing.
I do not think that is the way, because then you can either start with an template or create an entirely new drawing.What I want is to be able so select an existing drawing or create a new on basis of an template,.
You can use any existing DWG or DWT file as a "template".I mean , it is not necesary to "define them" as templates.So, NEWWIZ can work for this
That is correct, but it is very poor solution. in fact too poor. My appication does not load as when I use the template, and furthermore I cannot load the main LSP file, and there is no preview of the drawings to be opened.What I want is a choice like in Autocad with template, open a drawing, start from scratch, without loosing the path to the application to be loaded.The path I have to (!?) set in the Start in line from the shortcut where I start Bricscad from.
