TTF fonts
Would it be possible to have TTF fonts look more like they do in other applications, such as MS Word? At present, they are semi-bold when they should be normal/thin. Autocad has the same problem - is this a Windows limitation that appears only in CAD programs?
  • So do you get any fo the following problems with your TTF?Not only TTF come out outlined their hieght and spacing seems to change as well. THIS MUST BE FIXED STRAIGHT AWAY
  • I don't seem to have the other problems you mention - perhaps they are new to 2.2.0019. I'm still on 2.2.0016 myself.
