Dimensioning problems
Why do I often get dimensioning overides when I edit drawings created by someone using AutoCad? Also, I have received drawings that were created with AutoCad using a dimensioning style with architectural units that have the "diagonal" setting and the DIMTFAC variable set to 0.75. Those dimensions show up in BricsCad as stacked fractions, but they are very small. when I explode them and zoom extents, everything disappears!? Is this a bug?
  • BricsCad support says they can't duplicate the exploded dimension bug. Has anyone out there experienced this problem? I'm using version 6.2.0012 on WindowsXP.
  • HiI have been having problems with the entire drawing disappearing when I edit dimensions and move leaders etc, regen brings it back to view...
  • Everything seems to work fine now, with version 6.2.0019.
