Text background
Is it possible to change the text background in bricscad ?When i put text in a colored region the text is displayed in a blackrectangle. I want to have the text background to be the same as thecolor of the region it is displayed in.Regards,Henk Jan
If you place the color fill first, then the text on top of it the rectangles will not display. If the the text already exists use a Boundary Set in which the text is not included when creating the fill.
Sorry, I forgot something important: if you create the color fill on top of the text, use DRAWORDER and move the color fill to the back, otherwise the text will not be visible.
This works fine.Thanks,Henk Jan
