program crash
After a new install of wine 0.92 and the latst bricscad i can't get it running as a normal user. I keep crashing with a segmentation fault. While as user 'root' bricscad runs just fine. I suppose this isuser rights problem. Any suggestions how to solve this ?Regards Henk Jan
I kept getting segmentation faults until I renamed .wine so creating a new version.If it doesn't work you can always revert to the old .wine.
I tried this. With the old .wine i only got the splash screen before bricscad wentinto debug mode. with the new .wine it starts normally but when i try to load adrawing is crashes.This is only as a normal user. Root works ok.Henk Jan
I think it is a permissions problem. Bricscad can't make a new.wine directory and a error.log file.Henk Jan
For each drawing, a logfilenow is created in the path that the LOGFILEPATH system variable points to: see the options>paths dialog.If this is a matter of userrights, changing the logfilepath to a directory with appropriate permissions could fix that.Could you try that please?Unless you deliberately share the .wine/system.reg file between users, all users have completely separate registries. Normally each user has full access his/her .wine folder.kind regards,Alexander Van Heuverzwyn, Bricscad
I have a crash when I try to open an existing drawing with wine-0.9.5-2.fc4 if use wine-0.9.2-1fc4w I do not have problemserr:x11drv:X11DRV_CreateWindow invalid window width 1597608672err:x11drv:X11DRV_CreateWindow invalid window height -1447659err:x11drv:X11DRV_CreateWindow invalid window width 1597608672err:x11drv:X11DRV_CreateWindow invalid window height -1447659err:x11drv:X11DRV_CreateWindow invalid window width 1597608672err:x11drv:X11DRV_CreateWindow invalid window height -1447659err:x11drv:X11DRV_CreateWindow invalid window width 1597608672err:x11drv:X11DRV_CreateWindow invalid window height -1447659wine: Unhandled page fault on read access to 0x00000000 at address 0x31cfec9f (thread 0009), starting debugger...err:seh:start_debugger Couldn't start debugger ("winedbg --auto 8 296") (2)Read the Wine Developers Guide on how to set up winedbg or another debuggerRegardsGraziano Palamara
