sheet metal layouts
I am hoping someone out there with a sheet metalbackground could recommend a program for generatingflat layouts for cones, boxes, cylinders and etc. I'vefound some that run under Acad, but none that mightfly with Bricscad. Maybe someone has a lisp routinethat might do the trick.
  • Try "Sheet Lightning" from www.revcad.comYou can download a demo. It is parametric. You can export DXF files.
