linear unit "decimal"
It appears that the linear units choice of "decimal" is drawing in inches. Is there a way to set the "decimal" to always draw in feet? If I set the drawing unit setting linear to "decimal" it is drawing in inches. The same drawing line length when the linear unit is changed to Architectural is 1/12 the length.
Is there a way to have the linear units setting of "decimal" draw in feet instead of the default value of inches?
