Lisp - replace multiple lines with arcs?
HiDoes anybody know of a lisp routine that would replace a series of connected lines with arcs. ie an oval made up of say 200 line segments need to convert to arcs. (best fit)I use corel draw to create some vector art, the export to DWG is useless as it only exports polylines which explode to 1000's of line segments.Alternatively does anybody know of a vector to vector programme that wouild convert polylines to true arcs and lines.All the raster to vector programs only accept raster artwork and the results leave a lot to be desired.Any advice would be appreciatedRegardsKim Watson
  • You can write or find a lisp routine.An other method is to use the command PEDIT (Polyline Edit), select one of the lines, then the alternative Join and selct all the other lines, then the alternative Fit.
