Keyboard Shortcuts Missing
I upgraded to the latest version PRO and lost all my keyboard shortcuts. Is there a file that these are kept in that I can save so I do not loose them in the future?
To restore keyboard shortcuts when upgrading to a new version you must save your shortcuts first using the EXPORT function on the CUSTOMIZE > KEYBOARD window. Keyboard shortcut files have a *.ick extension by default. To import the shortcuts after upgrading use the IMPORT function on the CUSTOMIZE > KEYBOARD.Alternatively you can define a USER PROFILE using the PROFILE MANAGER, which you can find in the TOOLS menu, then launch Bricscad by choosing this profile in the PROFILE MANAGER window. Place a shortcut to UserProfileManager.exe on your desktop. This file sits in the Bricscad program folder (e.g. C:\Program Files\BricsCad\BricsCad)
