Ortho mode
Can someone help me with this: Is it possible to set the orthogonal mode so that lines drawn can snap to 45 degree increments as well as 90? Also, if that could work for mirror lines also, so that you could mirror things about a 45 degree line as well as 90 (in ortho mode). Is this possible now (how?), and if not can the functionality be added?
  • Not as far as I know.You can set a snapgrid at 45 degrees.Maybe that can help you.
