Hatch insert from Lisp command
Hello!I try to use "bhatch" command in a Lisp routine to insert hatch by indicating a point. The problem is that the lisp routine is stopped by the hatch dialog... Can I avoid this dialog appearance?For this, I think about a similar resolve and I have tested the old "hatch" command, not from a Lisp routine, just as a usual command, from the command line, but this produce a lot of bugs. Best regards,Ioan
Hiyou can try with -bhatch
Thank you... it works! :-)kind regards,Ioan
