Group Codes for LISP?
The AutoLISP programming book that I've purchased keeps refering me to the online AutoCAD Lisp documentation to get the list of group codes for various objects.I've been searching BricsCad's online documentation for this list, but can't find it.Any ideas where I might find such a list?Joe Dunfee
A Google search for "DXF group codes" will provide a number of good hits.http://www.autodesk.com/techpubs/autocad/acadr14/dxf/dxf_group_codes.htm
It seems I've been confused on the term. I've been deliberately looking for some list of codes that were NOT DXF group codes.A LISP book I purchased said "the DXF codes used in an association list are different from those used to generate a DXF drawing file." But, upon re-reading the book, I see it also says "The group codes used in an association list returned by AutoCAD are in the DXF format."So, I'm still a little confused, but will accept that for my purposes, a DXF group code is what I want. (I am not writing any DXF files).Thank you for your reply.Joe Dunfee
