Layers in sheets
I have imported a drawing file into a sheet. They are cabinet drawings and I create viewports on the sheets at different scales. I would like to turn off certain layers in one viewport but not the other. It appears I cannot do that. If I shut off a layer of text or change a layers properties in one viewport it does to all. Is this correct or is there a command I am missing?Thanks,Paul
