Fractions and Superscripts
Is there a way of writing say 1/10 (one tenth) or 2 to the power of 3 or metres cubed (m3) in ICAD Mtext or Dtext commands?I know you can write half ½ (Alt+0189) and quarter ¼ (Alt+188) but what about any other fraction?
I don't know how to do it in text but here are here are two examples of fractions in mtext. Create an mtext and put this in it.something\H0.5x;{\A2;mtop}\A1;/bottom;\Smtop/bottom; \A1;\H2.0x;continueMtext formatting is rich but the interface at the moment only implements the basic features.regards, sanderbricsnet
Are the Mtext formatting options documented anywhere?
Not at our place. Normally the user interface should do it for you. at the moment In icad you have full access to the formatting codes , so one can try out.\S is for stacking{ } creates a group and limits the scope of the formatting codes inside it \A1; moves the text upwards\A2; moves the text upwards a bit more\H2x; scales the size, here it doubles it\f changes the fontregards, sander
Thank you Sander,It works well enough except when using numbers with the stacked (\S) fraction such as 5 out of 10, the 5 gets the fraction line going through it. I tried to move the 5 up a bit using the codes above but couldn't do it. I used the Arial and txt font s with no success. The plot preview looked worse but it printed out as shown on the model space screen.I tried this:\fARIAL|b0|i0|c0|p34;something\H0.5x;{\A2;5}\A1;/10;\P\P\S5/10; \A1;\H2.0x;continueI use 2.2.0016c ICAD. It looks ok if you replace the numbers with capital letterseg: V instead of 5 and X instead of 10 in the stacked fraction above.Let me know if it works with your version.Best regardsAdelaide - South Australia
I work with primarily architectural drawings and use stacked fractions.I have found that one can explode an architectural dimension then edit the code to reflect the desired fraction.however, there is a bit of crowding going on between the whole number and the fraction. does anyone know of a work around?thanks in Advance,Jefferson.
