Dimension text in rotation
I have a base topo map on which I have been drawing the sitework. The building orientation is ~14deg off due north. I had inputed dimensions "aligned" with the sitework (~14deg). Then I rotated the whole drawing to get my building and patio horizontal/vertical. Everything rotated EXCEPT THE DIMENSION TEXT. (The dimension lines are fine). It shows as 0 degrees in the properties window, but the text is still rotated. When I try to change it, it rotates the whole dimension set, which I do not want to do.
