Odd scaling behaviour with linetypes
What can be wrong..?I have a model with different dashed/dotted lines (the ones that come with sw, each linetype on it's own layer) and I use STB to map linetypes. When I create a viewport with scaling 0.01 to achieve 1:100 scaling, all those lines are plotted with very sparse dotting/dashing. In dashdot linetype, the dots even disappear.I can get the plotting working quite well by changing the line entity properties in model to scale approx. 2.5 and setting thickness to 0 (value 1 makes dots to disappear).How to achieve a situation where linetypes would look correct in model view and also to print correctly with different scalings?
Please read about PSLTSCALE in Help/System Variables tosee if there is a solution there.
