Offset (parallel command) bug
I am now using version 2.2.0019, but I have noticed since version 2.2.0017c that the offset (or parallel) command sometimes behaves strangely. This did not happen with previous versions.If I am trying to offset a line, sometimes the line will be offset to the wrong side (as if I had clicked on the other side of it) and sometimes it will not be offset at all, and I will get an error message that the points need to be distinct (as if I had selected a point on the line to indicate offset direction). This may have something to do with running snaps -- I usually have endpoint, intersection, and perpendicular snaps on as running. This bug occurs sporadically and therefore is not always repeatable, but it has happened enough that I'm reasonably sure it's not just my mistake.
