Print all the help ... possible ?
HelloWhen i was using autocad2000 some years ago, it was provided with the program some big books explaining how to use the program and all the commands. Is it not possible to have a complete written documentation on bricscad and architecturals. I find it's more easy than to search in the helpfile in the pulldown menu.Is it possible to print all the help file in one time, or to change the help file in a pdf file and then to print ... Or how can i do?Maybe another solution ...Thx in advance - Richard Stas
One approach could be to generated Pdf-output by printing the on-line help. I have done this with the PdfCreator (http://sourceforge.net/projects/pdfcreator/)When using the print button of the on-line help you have the option to 'Print the selected heading and all subtopics'. You can sent the print to thePdfCreator. I would advice to create several Pdf files (one per main help heading). Then using the Combine option of PdfCreator you can producea single Pdf file which is the result of merging all the separate files into one.
Another approach could be to download and print the BricsCad PDF manuals.Here is the download procedure:ftp://Customer:bpw4cuslib@ftp.bricscad.com/Library/Eng-Us/Bcad/BricsCadPdfManual-V7.0-Eng-Us.exeor :FTP site : ftp.bricscad.comUser : CustomerPassword : bpw4cuslibThen go to the folder "\Library\Eng-Us\Bcad"Download the file "BricsCadPdfManual-V7.0-Eng-Us.exe".These manuals can also be found on the BricsCad CD.Double-click the file "BricsCadPdfManual-V7.0-Eng-Us.exe" to extract the PDF files.Password : A2h7-(mLOp)+3a9M
Thx for the helps.Ferdinand, about the online help, is it the little brochure documentation on bricscad V7 ?Thx - Richard Stas
