set printing scale via vba
hello everybody,i'd like to write a macro which does the following:display a dialog in which a can choose a scale (e.g. 1:500, 1:1000 etc.) and then prints/plots the current view to this scale.so far i did not find a possibility to set the scale via vba - is there an example code somewhere?regards helmut
  • There is the method of using the command line version of print. I haven't done that since the DOS days of AutoCAD version 10, but I see that it is still available.Joe Dunfee
