UCS icon will not disappear
I am using Bricscad v. 7.1.0011.Every time I start Bricscad the UCS icon is displayed. I have tried to use the command UCSICON and select OFF. Then is disappears from the display, but next time I start Bricscad the icon is back.What can be done to that?Svend
  • The display of the UCS icon is a Drawing setting. Therefore it can be set differently in each drawing. If you want the icon to be not displayed in each of your new drawings, witch the setting off in your template drawing(s).
  • Thank you. As far as I remember it was not pr. drawing in version 6, but it must have changed then.
