Hatch Question
I have recently downloaded the latest version of Bricscad and am now having a problem with boundary hatching. The new format first asks for the boundry. I use the "Select Boundary Set" and pick the area I wish to hatch. I then select the Predefined Pattern Type. When I go to the Pattern and either pick from the name or icon, the OK button remains dormant and does not "complete" the hatch action. Am I doing something wrong? The hatch option was different in prior versions and this was not a problem.
Nothing has changed in the hatch procedure compared to the previous versions. What has changed is that if the hatch is too dense, it will not be created. A message in the command window asks to increase the MAXHATCH variable. Is this what is happening?
I think I have the problem solved. It seemed to be the way I was selecting the pattern area. Thanks.
