Need help with printing using VBA
I am attempting to create a VBA routine, which will find all the titleblocks in modelspace and plot a window enclosing that titleblock.I can't find any good examples of printing from AutoCAD/BricsCad, and am just lost.I have found the following items in the Object Browser. the following,AcadLayout.SetWindowToPlot(LowerLeft, UpperRight)AcadPlotConfiguration.SetCustomScale(Numerator As Double, Denominator As Double)But, when I use the option to Complete Word (CNTL-SPACE) none of these appear. I find other similar choices, including;AcPlotScaleAcadApplication.ActiveDocument.PlotBricscadApp.AcadDocument.PlotAnyway, below is the code I currently have. But, get a compile error as noted below. I can assume that I already have the document in AutoCAD open and in modelspace.----------------------Dim LL(0 To 1) As DoubleDim UR(0 To 1) As DoubleDim MyPlotWindow(0 To 1)LL(0) = 0LL(1) = 0UR(0) = 158UR(0) = 228MyPlotWindow(0) = LLMyPlotWindow(1) = URAcPlotScale = 1/24AcadLayout.SetWindowToPlot = LL,UR ' VBA says it is expecting "end of ' statement" at the UR variableAcadDocument.PlotEnd Sub----------------------------I would greatly appreciate some advice.Joe Dunfee
This weekend we plan to release a new beta build V8.0.10. It will contain sample code for a batch printing tool. One version of the tool is implemented using COM (VB), a second version is implemented in LISP. Hope this will shed some light.Hans De Backer
Correction: unfortunately the sample code did not make it into V8.0.10. We will send it directly to you instead. It will be included in the next installer.
Of course, I thank Hans for the special attention he has given me by E-mailing me their example VBA code. But, am still having problems. The VBA example (A VBA batch plot utility) is just too complex for me to follow. I can't even find where the routine actually prints anything.Perhaps someone can help me with just one aspect. How can I set the plot scale? I see two methods.The first is a variable that I find when I use the "Complete Word" feature.AcPlotScale = 1/24But, when I compile the VBA code, it says the variable is not defined.So, I tried the other method I found in the Object Browser,AcadPlotConfiguration.SetCustomScale(1,24)VBA responds saying "Expected ="So, I tried AcadPlotConfiguration.SetCustomScale = (1,24)VBA highights the comma and says "Expected )"So, I triedAcadPlotConfiguration.SetCustomScale = (1)(24)Then VBA highlights the second "(" and says "Expected end of statement"Programming by guessing is obviously not getting me anywhere. What bit of understanding am I lacking?Joe Dunfee
Joe, without exactly knowing what you routine looks like here's a hint.Try:CALL AcadPlotConfiguration.SetCustomScale(1,24)or AcadPlotConfiguration.SetCustomScale 1,24 (Typical VB syntax, use a CALL and include brackets or ommit CALL and ommit brackets)Hope this helps,Arno van Eeuwen
I get a "Variable not defined" when I compile, and the word "AcadPlotConfiguration" is highlited in the code.Could this be related to the reference I've loaded? I have the following references loaded (they are listed in the order they are given;Visual Basic for ApplicationsBricscad App 1.0 Type LibraryOLE AutomationMicrosoft Forms 2.0 Object LibraryBricscad DB 2.3 Type LibraryJoe Dunfee
Apparently the example code you received will be included in the next V8 release. I can have a look at that when it's available. See if it makes sense to me.
)TTYLArno van Eeuwen
