Zoom center locked?
v6.2.0024 xp sp2Mousewheel zooming is locked to the center-right of the screen. Shouldn't it zoom in and out wherever the mouse is pointing?It's happening all the time in all drawings, even with upgrade to latest version of 6.
  • Ctrl>shft>left click always zooms from or to the screen centre, but the wheel should work as you say. It might be that snap is causing it (F9), otherwise I would look at the mouse settings or condition.
  • I'de rather be able to use the mousewheel, but the ctrl-shift trick is better than what I'm still stuck with. F9 has no effect. I'm not sure what you mean by "condition". All I know is that the mouse behaves normally in every program other than this one. I can't find any "mouse settings", other than the OS settings, which I haven't changed, and as I said, is operating normally in all other programs.The only thing left I haven't tried is a complete wipe of Bricsys from my machine and reinstall, and I'de like to avoid that.
  • I bit the bullet and did a complete wipe/reinstall. Problem fixed, but now I guess I'll never know what it was until it happens again.
  • Aha! The problem came back, and now I know why! I have a dual monitor setup with the right monitor as No 1. I moved BC to the left monitor, and zoom is stuck center-right! I moved it back to the right monitor, zooms normally!Jeeeeeezzzz....
  • For your information: this is one of the things that were fixed in V8...Kind regards,Hans
  • Glad you found the cause.I meant perhaps there was something wrong with your mouse, or the driver/program settings for some mice include things like "disable acceleration in games" and can inappropriately apply to Icad sessions but not to most other programs.
