add-in won't run on a saved drawing
I have an add-in (vb6 .dll) that runs fine on initial start up . When i run it from a saved or new drawing I get "unable to recognize command please try again", attempting to reload the dll returns that the application is already loaded.removing the file from the tools,load application, file list, and then reloading loads the dll but error remains. any suggestions?thanks mike
