V 8 save file path
When I set the my save file path in the settings it re-sets to the Windows temp file when I close the program. The caption for this setting says that it sets the path for the auto save files in "this session". Does this mean that you have to re-set it every time you re-open the pogram? Is this happening to everybody else or am I the only one?
  • This is indeed undesireable behavior. We will modify the code so the setting persists between sessions.Thanks for pointing this out.Hans De Backer Bricsys
