Embedding VBA in a drawing?
I believe I can embed VBA code in an Excel spreadsheet, but this doesn't seem possible in BricsCAD. Is it?For my project, I don't want my code to be in the default VBA file because I am concerned that problems in my code will cause problems even when I am not using that particular code. I would prefer to have the VBA automatically load when the template file is opened. I supposed I can make it easier by creating a Macro button to load the VBA.Any opinions about the best way to do this?Joe Dunfee
  • Don't think that is possible but I'm not sure.Why not make a new project and save it as a dvb file?you can easily load it with the project manager under "tools" "vba" "project manager", or with the load function.I don't see the danger with using the default project by the way. In v7 I had about 12 modules with several subs and fuctions each in commonprojects without any problem.With V8 I have to start all over again. Until now I have 2 modules :(
