Ordinate dims not stretching!
I am posting this here, because this can be a BIG issue. On the newest version 8,012 Build 8456, when you stretch an ordinate dimension, the value does not change.Joe Dunfee
  • Ordinate dimensions do stretch correctly if only the dim point (control point) is within the stretch boundary. When moved ordinate dimensions are not adjusted either. In V7 this was not different. Still, you have a point here and therefore I forwarded your remark to the development team.
  • Additionally, when selected so that the grips are shown, the origin of the ordinate dimension is not there. I think this should be shown, so that you can see where that particular ordinate dimension is originating from. (this is the behavior in AutoCAD)Joe Dunfee
  • When selected 3 grips show: origin, leader and text ...
  • I just rechecked my build #8567. When I select an ordinate dimension, the origin (where the dimension considers 0,0) is not highlightedI can see the ordinate dimension's origin point. If I select it, the dimension it is associated with becomes highlighted, but not the origin node itself. If I attempt to stretch that node, it will not stretch.Joe Dunfee
