Simple AddRegion in VBA
Copied this code from ACAD examples.Sub Example_AddRegion() ' This example creates a region from an arc and a line. Dim curves(0 To 1) As AcadEntity ' Define the arc Dim centerPoint(0 To 2) As Double Dim radius As Double Dim startAngle As Double Dim endAngle As Double centerPoint(0) = 5#: centerPoint(1) = 3#: centerPoint(2) = 0# radius = 2# startAngle = 0 endAngle = 3.141592 Set curves(0) = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngle, endAngle) ' Define the line Set curves(1) = ThisDrawing.ModelSpace.AddLine(curves(0).startPoint, curves(0).endPoint) ' Create the region Dim regionObj As Variant regionObj = ThisDrawing.ModelSpace.AddRegion(curves) ZoomAll End SubIt works in ACAD but not V8. Line & Arc are created but no region. Does anyone see the fix.Jerry
