an error has occured : null function
I download regularly autolisp routine from the website cadalyst.com.When trying to make run them under bricscad, a lot of them doesn't run.Is Bricscad not able to read and to run lisp routines designed for autocad ?Or what must i do ?THX - RSTAS
Some of those downloadable lisps are compiled, I am not sure if they work in Icad? Just a guess.
I can open them with a notepad editor and i can see the texts in the file *.lsp
Ah well that's probably not the problem. Is it V7 or V8? If you want you could send me a few and see if they work for me -jgaunt@bigpond.com.auI don't download many, but those I do have mostly worked. Compiled and other fancifications have usually been the problem if they didn't.I have a lot of my own small lisp routines, many of which I originally created in Acad and transported with no problems.
