mail command
The send mail command in the file menu opens an email with the current file attached, but it changes the name of the file to tmpmail#.dwgand doesn't attach fonts or external references.The command shouldn't change the name of the dwg file.It should prepare the email with the file attached inside a zip file and including all external references, such as fonts, xrefs and image files.Included should be a txt file with a full description of the file hierarchy.This isn't a really high priority, but it would be nice.
