point snapping durring a command bug
When you are in a command like Line and you shift-right click and select "Point Snap", the entity snap function will not work.It produces a command of "_nod" which does not activate the point snap function. But if you shift-right click and select "Point Snap" before the command it produces the command of " '_Node" which starts the running osnap command.This needs to be fixed.
  • It happens with me too.If you type _NOD yourself it doesn't work as well. If you type NOD it works. It is hardwired in the code, it's a bug and need to be fixed. As a workaround you could assign say F4 to be NODE and everytime you need it transparently hit F4.
  • I just changed it to "_POI" . This will work in the next release.
