Create Block Error
Dim blck as AcadBlockDim inspoint1 as VariantDim utilObj as AcadUtilitySet utilObj = ThisDrawing.UtilityutilObj.CreateTypedArray inspoint1, vbDouble, 0, 0, 0Set blk = ThisDrawing.Blocks.Add(inspoint,"Any")why a type mismatch error at last statement
Will this help?Dim blck As AcadBlock Dim InsPnt(0 To 2) As Double InsPnt(0) = 0 '= X coordinateInsPnt(1) = 0 '= Y coordinateInsPnt(2) = 0 '= Z coordinate Set blck = ThisDrawing.Blocks.Add(InsPnt, "Any")Arno van Eeuwen
No unfortunately not - same errorDoes it have something to do with the references in my project Amongst OthersBricsCAD DB 2.3 Type LibraryAutoCAD 2006 Type LibraryBricsCAD App 1.0 Type LibraryI have AutoCAD 2002,2006,2007 & 2008 installed
Try changing to this:Dim blck As BricscadDb.AcadBlockWith various Cad objects on one system, I also have had similar problems.By specifying specificly a 'BricsCad' Block, you avoid declaring an 'Autocad' block and then linking in to a BricsCad block.Hope this helps,Arno
Heres the rub! My BricsCAD DB Library doesn't expose an AcadBlock Object yet it does AcadBlocks. There is also an IAcadBlock although this seems to be DBX related
