help!
I have approximately 150 dwgs that My Company distributes on cds. I used Intellicad to draw all of them. Most Drawings consist of Architectural cad images with true type fonts used for description. these drawings were drawn for reference use only.After I upgraded to vernum 2.2.0016I have terrible alignment problems with some of my text. It would appear that the spacing between lines (arial font) has changed. and when i print using my gl\2 plotter driver all of my arrow heads are gone or there printing white on white.not to mention the font no longer looks like arial font. when i print using the standard driver everything looks great except for the font spacings. this may be a silly question but i also have one file that has all the text greeked and displayed as rectangular boxes. how can i change this??is there something im over looking?thanks in advance.Jeff
There is indeed a spacing problem with some fonts. We'll fix it soon.the rectangles can be toggled with the system variable qtextmode.
thanks for your help.my files look just fine in autocadbut in intellicad, the font is spaced differently.
I have noticed that some fonts look plenty weird in the print preview, but appear on screen OK and print OK as well. I guess this is part of what they're working on...
the print preview scaling problem is fixed in 2.2.0017.regards, sanderBricsnet
Is 2.2.0017 available for download? Has the transparent pop0 bug been fixed?ThanksAndre
