Ssget "c"
Hello !I have to select entities with only one point.The code (ssget <<>>) just gives one entity in the selection set..So i use another option of the function ("C").this function aks you two points to select crossing entities.If you put same points in the arguments, it returns all the entities under this point.Normally this function rules.Anyway with Autocad...But not with BricsCAD !!How can I pass away this bug ??Thank you, and sorry for my poor english !Matt.
  • "CC" for Crossing Circle may be a workaround.Use your point as center point and specify a small radius.
