Bricscad on Terminal Server
One client asks.Will Bricscad function OK on a MS Windows 2003 Terminal Server?Has anyone tried that?
  • I have the same question. Will Bricscad work well on a Windows 2008R2 Terminal Server?
    I did some tests and it seems to work. However, the ccrosshair movements sometimes have a very slow response on mouse movements. Sometimes it takes one second to react. Are there any settings which can improve the performance. I tested Bricscad V11 classic (evaluation version) on a HP Proliant ML150 server (8Gb memory) with no other load. I use the RDP program on a Windows XP client.
  • We have clients that work on Citrix Terminal server -
    due to their feedback, it seems to run fine there.
  • Thanks for your quick answer.
    My evaluation shows slow response on crosshair movements, up to 1 second delay.  Can we compare Citrix Terminal server with Windows 2008R2 Remote Desktop Services (formerly TS)?  Can it be dependent on the client, in this case WinXP RDP client? We consider to implement Briscad in our company as replacement of Autocad LT2008 for 10 users (only some are concurrent) using RDP .
