HATCHING
I am using v8. 0.23. I do not appear to have the hatch: AR-SAND, BRICK or LINE.Has anyone had the same problem?I use these hatch styles for external wall and roof coverings etc.Thanks
  • If you had those hatches before, you can add them to your current set of hatch patterns:1. Find and open the .PAT file that includes the pattern you want, say AR-SAND.2. Search for *AR-SAND, and select everything from that asterisk to the next. Copy it to the clipboard.3. Open default.pat in your user support folder (buried deep in C:Documents and Settings, etc. etc.) Skip to the bottom of the file, and paste the AR-SAND entry in.4. Restart BricsCad, and you'll find AR-SAND at the bottom of the patterns palette.Easier approach: The predefined pattern called DOTS2 is very similar to AR-SAND. I'm not familiar with the other two you mentioned, but there may be equivalents to them also.
