snaps and popups
Here are two problems I've been experiencing since using V8 (going through the forum I didn't find answers to these problems):1) Snaping to entities is not working, dispite being selected (endpoint, intersection...) and activated F3.2) How can I disable the popups that show up in the upright corner everytime I use a command? thanks for any answersnuno gouveia
- Can you check in the status bar whether Esnap is active (black) or not (grey)?- To switch off the prompt boxes choose SETTINGS in the SETTINGS menu, then under PROGRAM OPTIONS / DISPLAY choose PROMPT MENU and click the check box to switch it off.
Thanks Louis.The prompt menus are solved, but the enity snaps are not. Acttualy, if I shut down Bricscad and re-open it, the snaps will work fine for a few minutes, and then stop working.nuno
For me, the osnap settings have been completely stable in v8. But I had an equally strange problem with the Mirror tool. It wouldn't allow me to start a mirror line at an osnap point. I removed BricsCad, re-booted the system, and re-installed it (v8.0.23), and then the problem disappeared.
