insert a copy of a layer
Hi, How can i in Bricscad Explorer insert a copy of a layer ?If i use "copy" and "paste", i have a dialog box with -replace- , -skip-, ...I wish do a copy of a layer and rename this new layer for working insideThx RSTAS (Bricscad V7)
You can do that in v8. Select a layer, Copy it, rename it, then Paste, which creates a new layer with the same properties and the original name.
